FabianL
7 months agoNIOS V: Systick based timeouts not available when using internal timer
Hello, We are using Quartus 25.1 Standard. I came across something, which I would consider a but in the BSP generated HAL files, or at least a major limitation in the usage of NIOS V. System Set...
- 7 months ago
Hi FabianL
It is scheduled to be fix in the following versions of Quartus :
Quartus® Prime Pro Edition Software 26.1.1Pro
Quartus® Prime Standard Edition Software 26.1std
Jingyang, Teh
FabianL
7 months agoThanks for the confirmation.
Changing the file manually works as expected. But the file gets overwritten every time the BSP gets regenerated. Therefore I personally prefer using an external timer, as this is far more reliable.
2 Questions remain:
- Could you already give a hint, in which version this bug is scheduled to be fixed?
- Is there any other side effect of having the NIOS initialized last (as it is currently generated from BSP), besides that timer & alarms are not working for other drivers?
best regards
Fabian
- tehjingy_Altera7 months ago
Hi FabianL
Jingyang, Teh
