qianyi
7 months agoNios V Logic Element not include
Hi, Currently, we are using Nios V/m in Max10 (10M08) with Quartus 24.1std. However, we observed that the logic elements for Nios V/m are not reflected in the compilation. We also tried recreatin...
- 7 months ago
Hi QY,
I followed the steps in the AN 985 user guide, but I can not replicate the issue you are seeing;
Could it be that niosv.data_manager is not connected to jtaguart.avalon_jtag_slave?
That is very likely the issue. The Nios V is only connected to internal memory in your design. I.e. it has no connections to the outside world and as such has no useful functionality. The Quartus Tool removes any such blocks. My guess, the Nios V got optimized away.
Please connect the CPU like I have done below and try again.Cheers,
Richard
EstebanVV_Altera
7 months agoHi, just checking.... Did you started from this
https://docs.altera.com/r/example-designs/850270/current?
I just compiled and I can see the logic element count for the NIOSV/m
Please share your process...
