Nios V Hardware Interrupt Limitations
We wanted to check if there have been any updates or progress on this ticket.
Thank you very much for your support.
The Nios V/g CPU now supports the Core Level Interrupt Controller, which extends the number of interrupt sources to 2048. The Nios V/c supports the ext_int input, which can be used to connect an external interrupt controller.
Kind regards,
Richard
- fa_fpga_enthusiast10 months ago
Thank you for the clarification.
Could you please confirm from which Quartus version the following features are officially supported?
- Core Level Interrupt Controller support for Nios V/g (up to 2048 interrupt sources)
- Support for the ext_int interface on Nios V/c for connection to an external interrupt controller
In particular, we would like to know whether these capabilities are already available in Quartus 25.1.
Kind regards,
- RichardH_Altera10 months ago
CLIC for Nios V/g is available in 25.1
Interrupt support for Nios V/c will be available in 25.3.1Kind regards,
Richard
