watanabe's avatar
watanabe
1 month ago
NIOS V Core Not Recognized in RiscFree IDE 25.2.1 Run Configuration
I am trying to run software that I developed using Quartus Prime Lite version 25.1 and RiscFree IDE version 25.2.1.
However, in Run As > Run Configurations > Ashling RISC-V Hardware Debugging, the NIOS V core is not recognized in the Core Selection field under Target Configuration. The PIC is recognized correctly in the Device/TAP Selection field.
I have found that this issue has occurred with some previous versions, but I would like to know whether this problem can also occur with RiscFree IDE version 25.2.1.
If there is a known solution or workaround, I would appreciate any advice.
I have attached screenshots of the issue for reference.
  • watanabe's avatar
    watanabe
    Thank you for your response.
    I followed the steps you suggested, and the issue has been resolved successfully.
    I appreciate your help and support.
    • SueC_Altera's avatar
      SueC_Altera
      wantanabe,
      Thanks for letting us know you got it working!
      Sue
  • Naji_Naufel_Arrow's avatar
    Naji_Naufel_Arrow
    Hi Watanabe,
    This can happen if the MAX10 hardware is not configured with the NIOS-V design.
    1. Which NIOS-V variant (/c, /m)?
    2. Have you downloaded the .sof to the MAX10 prior to opening RiscFree?
    3. Did you enable Debugging for the NIOS-V core?
    Thank you,
    Naji
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
