NIOS V Compiler Settings/Optimizations
- 4 years ago
Hi Sleepy
The small c library options not available for the NiosV, however there is the lightweight device driver option.
You could find the parameters to reduce code footprint in the BSP editor.
Below is a link to edit the interface to edit the BSP.
You could refer the old Nios II BSP settings to reduce code size in table 54 in the document below.
Do take note that the small c library option is no longer supported in NiosV.
Jingyang, Teh
Hi Sleepy
Jingyang, Teh
