13 years agoNios terminal with copy to file inserts white space
I have a nios processor connected via USB blaster to the command line nios2 terminal. This works as expected.
I want to copy the output to a file as well as using the terminal so within the nios command shell I use: nios2-terminal.exe | tee /cygdrive/c/logfile.txt This generates the logfile correctly (in C:\Users\<user>\AppData\Local\VirtualStore\logfile.txt), however the output which appears on the terminal has blocks of extra white space in it every few lines of output. Is this normal for other users? I am using Quartus web edition v12.1.No RepliesBe the first to reply
