21 years agoNios systems - programing EPCS
Hello experts I have build nios2 board and it work just fine - no problem with it. But in software tools to many problems So we are using command line to compile and download SW code...
21 years agoHi AlexS,
> Can you explain or just show command line how to download HW+SW into EPCS ? for your sw elf file (sw.elf): $ elf2flash --epcs --base=0x0 --end=0x7fffffff --input=sw.elf --output=sw.flash $ nios2-flash-programmer --epcs --input=sw.flash --sof=<PGM> for your hw sof file (hw.sof): $ sof2flash --epcs --input=hw.sof --offset=0x0 --output=hw.flash $ nios2-flash-programmer --epcs --input=hw.flash --relocate --sof=<PGM> The <PGM> is the sof file for your flash programmer design. Regards, --Scott
