11 years ago
nios system download to epcs4 failed
hi everyone, i want to download my project to epcs, i do the follows
1.i build a nios project which includes sdram, EPCS/EPCQx1 Serial Flash Controller, and the reset vector memory of the nios is epcs_flash_controller_0.epce_control_port(of course there are sysid pll, and so on), i change the Dual-Purpose Pins to "Use as regular I/O";
2.the software project is very simple, just led the led blink;
3.in the eclipse, i debug the project, and it works(the led blinking)
4.i download the sof and elf file though flash programmer,
5.when i finish the download, the flash programmer did not tell me the download is failed, but the led is not blinking, so at least the nios did not run.
the "processing" content in flash programmer
Info: Info: *******************************************************************
Info: Info: Running Quartus II 32-bit Convert_programming_file
Info: Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=E:/qiaodong/altera/SF-CY3/SF_CY3_DVD/prj/ex2/flash/ex2_epcs_flash_controller_0.opt E:/qiaodong/altera/SF-CY3/SF_CY3_DVD/prj/ex3/ex2.sof E:/qiaodong/altera/SF-CY3/SF_CY3_DVD/prj/ex2/flash/ex2_epcs_flash_controller_0.pof
Info: Info (210033): Memory Map File E:/qiaodong/altera/SF-CY3/SF_CY3_DVD/prj/ex2/flash/ex2_epcs_flash_controller_0.map contains memory usage information for file E:/qiaodong/altera/SF-CY3/SF_CY3_DVD/prj/ex2/flash/ex2_epcs_flash_controller_0.pof
Info: Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings
Info: Info: Peak virtual memory: 185 megabytes
Info: Info: Processing ended: Tue Jun 16 13:44:49 2015
Info: Info: Elapsed time: 00:00:01
Info: Info: Total CPU time (on all processors): 00:00:01
Info: Info: Command: quartus_cpf --no_banner --convert E:/qiaodong/altera/SF-CY3/SF_CY3_DVD/prj/ex2/flash/ex2_epcs_flash_controller_0.pof E:/qiaodong/altera/SF-CY3/SF_CY3_DVD/prj/ex2/flash/ex2_epcs_flash_controller_0.rpd
Info: Info: Peak virtual memory: 180 megabytes
Info: Info: Processing ended: Tue Jun 16 13:44:51 2015
Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Info: Resetting and pausing target processor: OK
Info: Reading System ID at address 0x00012010: verified
Info:
Info: : Checksumming existing contents
Info:
Info: 00000000 : Verifying existing contents
Info:
Info: 00010000 : Verifying existing contents
Info:
Info: 00020000 : Verifying existing contents
Info:
Info: 00000000 : Reading existing contents
Info:
Info: 00010000 : Reading existing contents
Info:
Info: 00020000 : Reading existing contents
Info:
Info: Checksummed/read 51kB in 1.4s
Info:
Info: 00000000 ( 0%): Erasing
Info:
Info: 00010000 (33%): Erasing
Info:
Info: 00020000 (66%): Erasing
Info:
Info: Erased 192kB in 1.6s (120.0kB/s)
Info:
Info: 00000000 ( 0%): Programming
Info:
Info: 00010000 (33%): Programming
Info:
Info: 00020000 (66%): Programming
Info:
Info: Programmed 142KB +50KB in 4.6s (41.7KB/s)
Info: Did not attempt to verify device contents
Info: Leaving target processor paused
Info:
Info:
Info:
Info:
Info: Checksummed/read 32kB in 0.8s
Info:
Info: 00020000 ( 0%): Erasing
Info:
Info: Erased 64kB in 0.5s (128.0kB/s)
Info:
Info: 00020000 ( 0%): Programming
Info:
Info: Programmed 33KB +31KB in 1.5s (42.6KB/s)
the "infromation" content in flash programmer
INFO: Generating shell script of launched commands.
INFO: Generated shell script: E:\qiaodong\altera\SF-CY3\SF_CY3_DVD\prj\ex2\script\flash_programmer.sh
the "problems" content in flash programmer
WARNING: Obtaining system ID information for selected processor
software codes:# include "alt_types.h"# include "altera_avalon_pio_regs.h"# include "sys/alt_irq.h"# include "system.h"# include <stdio.h># include <unistd.h>
void delay(void);
int main(void)
while(1)
IOWR_ALTERA_AVALON_PIO_DATA(PIO_BASE,0x1);
delay();
IOWR_ALTERA_AVALON_PIO_DATA(PIO_BASE,0x0);
delay();
return 0;
//delay function
void delay(void)
alt_u32 i =0;
while(i < 100000)
i++;
1. is the download success or not?
2. if the download success, why the nios does not run?(the led not blink)
3. if the download failed, how can i do?
thanks!
    You are downloading your program into EPCS4. So after downloading, you need to apply power cycle to board ( power off and then power on ) in order to boot FPGA from that EPCS memory. Are you checking after applying power cycle to board?
    Cheers,
    Bhaumik
    Maybe you can try to use Quartus II programmer to program the .sof and .elf files in .jic file format? You can refer to these solution link on the steps to generate the .jic file from .sof and .elf files.
    https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04112006_450.html
    https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10132010_126.html
    Then you can refer to AN370 on how to program the .jic file. The Quartus II programmer will tell if the programming is successful or fail.
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an370.pdf
    thanks!
    i try to generate the .jic file
    when i use "sof2flash --epcs --input=ex2.sof --output=hw.flash --verbose" the command shell tell me "please supply an offset where you would like your sof located <--offset>"
    so i use "sof2flash --epcs --input=ex2.sof --output=hw.flash --verbose --offset=0x0 "(i do not know whether offset=0 is right)
    then the hw.flash file is generated
    then i use "elf2flash --ecps --base=0x0 --end=0x7ffff" --after=hw.flash --input=test2.elf --output=sw.flash"(0x7ffff is the size of M25P40 )
    then the sw.flash file is generated, but its size is 1Kb and content is
    "S00600002D454C3B
    S70500000000FA"
    i do not think it is right, so i think the base and then end address may not refer to M25P40, so i change them to base and end of EPCS/EPCQx1 Serial Flash Controller in Qsys, that is 0x01001000 0x010017ff
    then i use "elf2flash --ecps --base=0x01001000 --end=0x010017ff" --after=hw.flash --input=test2.elf --output=sw.flash"
    then the command shell tell me
    "elf2flash: Boot copier file name required
    elf2flash: Error generating Flash file, exiting"
    i do not know where to find the Boot copier file....
    --- Quote Start ---
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    Info:
    void delay(void);
    int main(void)
    while(1)
    delay();
    delay();
    return 0;
    //delay function
    void delay(void)
    alt_u32 i =0;
    while(i < 100000)
    i++;
    thanks!
    --- Quote End ---
    Have you fixed this problem, I face same here, Need your help :)
    hi phongvd2
    i already give up using nios.
    1. i suggest use mcu(stm32 for example) +fpga instead of nios in FPGA
    2.if you are chinese, to solve this problem, you can visit &#40657;&#37329; forum to find answers
