11 years agonios system download to epcs4 failed
nios system download to epcs4 failed hi everyone, i want to download my project to epcs, i do the follows 1.i build a nios project which includes sdram, EPCS/EPCQx1 Serial Flash Controller...
11 years agoHi,
Maybe you can try to use Quartus II programmer to program the .sof and .elf files in .jic file format? You can refer to these solution link on the steps to generate the .jic file from .sof and .elf files. https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04112006_450.html https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10132010_126.html Then you can refer to AN370 on how to program the .jic file. The Quartus II programmer will tell if the programming is successful or fail. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an370.pdf
