11 years agonios system download to epcs4 failed
nios system download to epcs4 failed hi everyone, i want to download my project to epcs, i do the follows 1.i build a nios project which includes sdram, EPCS/EPCQx1 Serial Flash Controller...
11 years agothanks!
i try to generate the .jic file when i use "sof2flash --epcs --input=ex2.sof --output=hw.flash --verbose" the command shell tell me "please supply an offset where you would like your sof located <--offset>" so i use "sof2flash --epcs --input=ex2.sof --output=hw.flash --verbose --offset=0x0 "(i do not know whether offset=0 is right) then the hw.flash file is generated then i use "elf2flash --ecps --base=0x0 --end=0x7ffff" --after=hw.flash --input=test2.elf --output=sw.flash"(0x7ffff is the size of M25P40 ) then the sw.flash file is generated, but its size is 1Kb and content is "S00600002D454C3B S70500000000FA" i do not think it is right, so i think the base and then end address may not refer to M25P40, so i change them to base and end of EPCS/EPCQx1 Serial Flash Controller in Qsys, that is 0x01001000 0x010017ff then i use "elf2flash --ecps --base=0x01001000 --end=0x010017ff" --after=hw.flash --input=test2.elf --output=sw.flash" then the command shell tell me "elf2flash: Boot copier file name required elf2flash: Error generating Flash file, exiting" i do not know where to find the Boot copier file....
