21 years agoNIOS Starter Info
Hello guys, I'm a total NEWBIE with NIOS. I'm just a 2nd yr undergrad student trying to compile some C++/C code to the assembly code for NIOS. I need to do some other analysis with the ass...
21 years agoIf you create your project in the IDE then the HAL makefiles will already contain the correct rules to make assembler files.
Just type `make obj/<filename>.s` from a shell. You can get preprocessed files (.i files) in a similar way.
