17 years agoNIOS SOPC Flash Memory Interface (CFI)
I am trying to read the Query values from a CFI compliant flash device, a PC28F128P30b85. I have implemented a NIOS SOPC solution with a tri-state bridge module and cfi-flash module. The cfi-...
17 years agoDo you have a Nios with Datacache ?
If yes, make shure that you use the cache work around. you could easily test the cace problem by compiling nios without data cache and see if anything changes. there is a HAL function for remaping or something like that you could also set adr. bit 31 as cache bypass.
