17 years agoNIOS SOPC Flash Memory Interface (CFI)
I am trying to read the Query values from a CFI compliant flash device, a PC28F128P30b85. I have implemented a NIOS SOPC solution with a tri-state bridge module and cfi-flash module. The cfi-...
17 years agoone common mistake is to setup the cfi for 16 bit mode but connect it as 8 bit device.
when you have a 16 bit device, then you have no address bit 0 as the would always be 0 indicating even address access. so check wheter you have connected nios a1 to flash a0. some flash device have adressbit [-1] that is used in 8 bit mode and is a databit in 16bit mode
