13 years agoNIOS Software appears to restart
I built a first generation "larger than life" version of a product using an EP4CGX75 FPGA, and got my system and software running. I now have an ultra-miniature version of this using an EP4CGX15 part...
13 years agoI don't use Eclipse that much, but IIRC when you create a new project there should be two of them. A BSP, that is linked to the sopcinfo file, and the application itself, that is linked to the BSP. Are you sure you recreated both projects? I think that when you create a new project in Eclipse, you have the option to create both the Nios2 application and the BSP at the same time.
