15 years agoNIOS simulation in Modelsim
Hi! My boss asked me to put together a NIOS system and simulate it successfully in Modelsim, and then show him how to do it. I was able to get the "Hello World" example to work (only when the ...
15 years agoSimulation will take a while if you don't turn on the simulation support in your BSP. When this is enabled things like flushing the cache and other optimizations will not happen. Also don't forget to turn this option off when you want to run your software in hardware as these shortcuts should not be present when run in real hardware.
What you are attempting should be possible.
