21 years agoNIOS SDRAM performance
I have measured the speed of memcpy's of NIOS2. I use optimized code consisting of four consecutive READs and four consecutive write accesses. Code snippet: while (i--) {
d0 = __built...
21 years agoHi Dirk,
What you're seeing is the result of the Nios data master not being 'latency aware' (the instruction master is, and this allows relatively speedy instruction fetch even with a cache miss). Both master ports on the DMA controller are, and that is why Ken sees the performance he does. In a nutshell, Nios II was really designed to be as simple (small/fast) as possible and deliver best performance when things are cached. However, you raise a valid point with respect to more complex systems that have custom logic or other processors sharing memory -- as such things cannot be cached. I'll have a chat with our CPU expert to see what the penalty for adding latency awareness to the data master would be. In the mean time I have to second the opinions above for either using DMA (which sounds like something you don't want to do), or dedicating a small on-chip RAM(s) to your high-speed buffers. The onchip memories can also be dual-ported, further enhancing performance. PS: Latency aware means that an Avalon master accepts the 'readdatavalid' signal, rather than merely the 'waitrequest' signal as all masters must do.
