bob_bitchen's avatar
bob_bitchen
3 years ago
NIOS SDK tools don't see memory region
We use an Arrow LPDDR controller from the BeMicro designs back with Quartus 12.
I have a CIV E design in Quartus 21 lite with a NIOS II F.
In platform designer, the NIOS vector selection drop-down boxes have the selection for mddr_ctrl_0.avalon_slave, and appears to generate the system successfully along with the sopcinfo file appears to have all the necessary items.
The tcl file is from a previous version, but it does have "is_memory_device" set to true.
The bsp generation scripts show the following:
Executing: wsl nios2-bsp hal . ../../Aggs.sopcinfo --cpu-name nios2_gen2_0 (D:\Altera\Kits\PCIe-AGGS\software\bsp)
nios2-bsp: Using /mnt/d/intelfpga_lite/21.1/nios2eds/sdk2/bin/bsp-set-defaults.tcl to set system-dependent settings.
nios2-bsp: Creating new BSP because ./settings.bsp doesn't exist.
nios2-bsp: Running "nios2-bsp-create-settings.exe --sopc d:/Altera/Kits/PCIe-AGGS/Aggs.sopcinfo --type hal --settings ./settings.bsp --bsp-dir . --script d:/intelfpga_lite/21.1/nios2eds/sdk2/bin/bsp-set-defaults.tcl --cpu-name nios2_gen2_0"
INFO: Creating BSP settings file...
INFO: nios2-bsp-create-settings --sopc d:/Altera/Kits/PCIe-AGGS/Aggs.sopcinfo --type hal --settings ./settings.bsp --bsp-dir . --script d:/intelfpga_lite/21.1/nios2eds/sdk2/bin/bsp-set-defaults.tcl --cpu-name nios2_gen2_0
INFO: Initializing SOPC project local software IP
INFO: [Info] <b>D:/Altera/Kits/PCIe-AGGS/*</b> matched 112 files in 0.10 seconds
INFO: [Info] <b>D:/Altera/Kits/PCIe-AGGS/*/*_sw.tcl</b> matched 0 files in 0.00 seconds
INFO: [Info] <b>D:/Altera/Kits/PCIe-AGGS/ip/**/*_sw.tcl</b> matched 0 files in 0.00 seconds
INFO: [Info] <b>D:/Altera/Kits/ip/**/*_sw.tcl</b> matched 0 files in 0.00 seconds
INFO: Finished initializing SOPC project local software IP. Total time taken = 2 seconds
INFO: Searching for BSP components with category: driver_element
INFO: Searching for BSP components with category: software_package_element
INFO: Found Flash Memory: epcs_flash_controller_0 for CPU: nios2_gen2_0
INFO: Loading drivers from ensemble report.
INFO: Finished loading drivers from ensemble report.
INFO: Tcl message: "STDIO character device is jtag_uart"
INFO: Tcl message: "System timer device is sys_clk_timer"
SEVERE: CPU "nios2_gen2_0" reset memory "mddr_ctrl_0" has no matching memory region.
WARNING: Tcl script "bsp-set-defaults.tcl " error: CPU "nios2_gen2_0" reset memory "mddr_ctrl_0" has no matching memory region.
SEVERE: [Error] altera_hal_linkerx_generator: Required linker section mappings do not exist: "[.entry, .exceptions, .rodata, .rwdata, .text, .bss, .heap, .stack]"
SEVERE: nios2-bsp-create-settings failed.
nios2-bsp: nios2-bsp-create-settings.exe failed
I tried digging into the tcl files that print those messages, but I think the .exe is writing those errors.
Help!!
  • Hi,
    What is the DDR that is use for your Cyclone IV board in your design?
    And what was the IP that was used to make the "mddr" controller in the Quartus 12?
    • bob_bitchen's avatar
      bob_bitchen
      From the first line:
      "We use an Arrow LPDDR controller from the BeMicro designs back with Quartus 12."
      You have the verilog file in all of the attachments.
      Here is the top of that file:
      /* Project: BeMicro SDK */
      /* Module: mddr_ctrl (mobile DDR SDRAM controller) */
      /* Author: Harald Fluegel */
      /* Arrow Central Europe GmbH */
      /* This module is a controller for the mobile DDR memory device mounted */
      /* on the Arrow BeMirco SDK evaluation board. The device is a Micron */
      /* MT46H32M16LFBF-5 low power DDR SDRAM with the properties listed below. */
      /* o Configuration 8M x 16 x 4 banks */
      /* o Refresh count 8K */
      /* o Row addressing A[12:0] */
      /* o Column addressing A[9:0] */
      /* Note that this is a low-performance controller that runs the DRAM on */
      /* a divided clock. */
      /* History */
      /* 2011-08-29: initial release */
  • Dear customer,​
    Thank you for reporting the issue, we have prioritized on investigating the bugs and getting the fix as quick as we could. However, we are unable to provide guidance when this bug will be addressed now. ​
    With this, I now transition this thread to community support. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. If you still need further assistance, you are welcome open a new case, please login to ‘https://supporttickets.intel.com’, someone will be right with you.
  • Hi,
    The alternate workaround is to use the EPCQ as reset vector and OCRAM as exception vector for newer Quartus, this worked. And set the BSP as following:
    Again, thank you for reporting the issue, we have prioritized on investigating the bugs and getting the fix as quick as we could. However, we are unable to provide guidance when this bug will be addressed now. ​
      bob_bitchen
      On 9-14-22
      community.intel.com/t5/Nios-II-Embedded-Design-Suite/NIOS-SDK-tools-don-t-see-memory-region/m-p/1414818#M51475
      We moved the vectors to EPCQ and OCRAM a couple of months ago and successfully produced the elf. However, the MDDR still was not able to be used as a target for the linker.
      I sent a screenshot of the functional MDDR being tested by entering its address on the command line of the memtest example.
      Nothing has changed on the bug since then except for people asking the same questions.
      I know that this level of support for your customers is acceptable to you, but our customers will not tolerate it.
