NIOS SDK tools don't see memory region
The alternate workaround is to use the EPCQ as reset vector and OCRAM as exception vector for newer Quartus, this worked. And set the BSP as following:
Again, thank you for reporting the issue, we have prioritized on investigating the bugs and getting the fix as quick as we could. However, we are unable to provide guidance when this bug will be addressed now.
With this, I now transition this thread to community support. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. If you still need further assistance, you are welcome open a new case, please login to ‘https://supporttickets.intel.com’, someone will be right with you.
- bob_bitchen3 years ago
On 9-14-22
community.intel.com/t5/Nios-II-Embedded-Design-Suite/NIOS-SDK-tools-don-t-see-memory-region/m-p/1414818#M51475
We moved the vectors to EPCQ and OCRAM a couple of months ago and successfully produced the elf. However, the MDDR still was not able to be used as a target for the linker.
I sent a screenshot of the functional MDDR being tested by entering its address on the command line of the memtest example.
Nothing has changed on the bug since then except for people asking the same questions.
I know that this level of support for your customers is acceptable to you, but our customers will not tolerate it.
