20 years agoNios SDk Shell can't display my inputs
type:nios2-terminal and waiting for running my program. But Nios SDk Shell can't display my inputs during running my program. But in nios IDE console,I can see my inputs. So WHY?...
20 years agoIt's a different flow for developing on uCLinux. The binary format is even different: FLT versus ELF. You might want to take a look at the nios wiki (http://nioswiki.jot.com/) for further info.
As far as your situation, you'd have to download your application to the running uCLinux system or, alternately (and better, I might add), you could just copy your executable to an NFS share on your host computer. [EDIT] Or...add your application to your file system. Best of luck. I think there's a sample "Hello World" app. that you can try. Cheers, - slacker P.S.: Though others have stated it here, you ought not to be using Windows to develop a Linux (or in your case) uCLinux application.... If you're going to develop for uCLinux, might as well work on a similar host!
