16 years agoNios SBT in ver10.0
Ok been trying out the new 10.0 stuff Yay on one thing: Finally GCC4. Anyway after going through and modifying patches to BSP stuff and fixing up some of the warnings that are now picked up with...
16 years agoOK
I tried some other stuff today and tried to create a test NIOS SBT App from a template.. This seemed to go ok, and violla there was a debug using nios hardware link available.. So I went a looked at the project properties and some aditional sections were now available regarding Nios II Application Properties. So I went at did a diff on the .project files and noted the following differences between the imported Custom Makefile Project and the one I created as a new one via the Nios II App and bsp from template.. The following entries were present in the <buildSpec> section of the template created one but were missing from my project file. <buildCommand> <name>com.altera.sbtgui.project.makefileBuilder</name> <arguments> </arguments> </buildCommand> <buildCommand> <name>com.altera.sbtgui.project.makefileBuilder</name> <arguments> </arguments> </buildCommand> And yep there were 2 of them... I don't exactly know why.. another bug I guess..?? And toward the end of the file there were these entries added to the <natures> section <nature>com.altera.sbtgui.project.SBTGUIAppNature</nature> <nature>com.altera.sbtgui.project.SBTGUIManagedNature</nature> So I added these entries into my .project file that the SBT's created during the import. restarted the SBT and guess what I now have the debug via nios ii hardware option and the drop down boxes are populated.. So I guess the import feature to bring in a custom makefile project is broken and is not adding in these settings to tell the SBT that hey this is a nios application.. Or something has changed in the way this import expects things to be within the makefile. We've been using these makefiles since version 8 of quartus and they are based on the altera ones.. As a further test I tried editing my project file again and only included the: <nature>com.altera.sbtgui.project.SBTGUIAppNature</nature> line. This seemed to work without needing the other entries so I guess that is the critical one that is missing when doing the import.. I will see how things go tomorrow on some actual hardware.
