19 years agoNIOS read from SRAM
hey all, i've been trying to read data from the SRAM on a DE2 development board using a program run in the NIOS II IDE. i'm not sure i'm using the proper calls, because i'm...
19 years agoAre You sure that your ssram work propery. Check the conection between fpga and ssram ,current and timing assignments. good luck !. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
