16 years agoNIOS Processor Fails to Reset
We're using a Cyclone III FPGA with a NIOS processor & custom designed logic. The system was built using Quartus V8.1. A configuration sequence can be forced via an external watchdog timer. When the ...
16 years ago --- Quote Start --- I suspect the RAM or the interface to the RAM first. Try holding the NIOS in reset much longer than the DDR controller and see what that does. Jake --- Quote End --- An update..... I did what you suggested. I isolated the reset to the processor & made the reset pulse to the processor longer (increased from 870 ns to 1.4us). Initially, this did not make a difference. I then changed the logic that resets the processor so that I could reset just the processor from an external switch. The processor would successfully reset & execute code when the switch was pressed. I then modified the processor reset logic to remove the external reset, and to make the pulse width REALLY long (5 seconds). This did the trick. The system would now take a reset from the watchdog timer & the processor would start up & execute code. Before, when a configuration & reset was initiated from the watchdog, the FPGA would configure, the non-processor FPGA logic would run, but the NIOS would not start. After some experimentation, I discovered that I could make the processor pulse width as short as 360ms & the processor would successfully reset & execute code. Any shorter, & I would see the original problem. Right now, I believe that there is some sort of race condition with the processor & the way the memory subsystem is starting up. I modified the FPGA design so that the processor pulse width is 670ms & is a separate signal from the reset signal that resets Flash & DDR DRAM controller. The Flash & DRAM controller reset signal is asserted at the same time, but only is 870ns wide. I successfully tested the change on both boards that previously exhibited this problem. I also successfully tested the change on boards that previously were working. Finally, I did some repeat testing on one of the boards that previously failed by forcing a watchdog timer reset >10 times. Each time, the system would now come up & run properly. Due to time constraints, this is as far as we're going to take this problem at this point unless it resurfaces. Thanks for all your help & your suggestion. Fred O
