16 years agoNios Problem
Hello, I am runnning a simple hello program using DE2-70. But still getting error mssage as: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Readin...
16 years ago --- Quote Start --- you have changed the device but keept the footprint ? you should check which pins have no exact pin location assignments if you have the chance to get access to the version with the prious device, open the project, go under menue -> Project -> organize quartus II settings file and exit this project. now your qsf file is sorted. You will find a section labled as# Pin & Location Assignments# ========================== with all the location assignments, you can copy this into you actual qsf and replace the assignsments there you will also find some other sections for the fitter and pin functionality if used like current strength or fast output assignments, you should also copy them. 192 out of 212 means nearly none ;-) --- Quote End --- There are lot of .qsf file when i search the harddrive. Which one should be imported?
