16 years agoNios Problem
Hello, I am runnning a simple hello program using DE2-70. But still getting error mssage as: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Readin...
16 years agoverify failed could have several possible couses.
do you have timing violations reported by your timing analyzer ? is this memory location internal memory or external memory ? if external, and if sdram have you setup thescdram clock phase correctly ? if external, have you checked your pinning and connection ? can you run a very simple design, just nios and internal memory on your target ?
