16 years agoNios Problem
Hello, I am runnning a simple hello program using DE2-70. But still getting error mssage as: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Readin...
16 years agoHi,it maybe some reasons as list:
Firstly you should know where is the address(SOPC every component has its address).Mostly errors happen in the memory or sdram. Secondly,you need to exam you PCB board. And then check every component to find if some interface got wrong links. Last,check the Quartus project:to see if the pio setting right or pll phase shift. Above all,your Nios IDE programme must be right!
