21 years agoNIOS power up and reset
Hello: My question has to do with the power up considerations of a NIOS system. Particulary the signals RESET and CONFIG_DONE. I have power supply monitors that watch the system voltages ...
21 years agoGeorge,
from what I understand, Nios II does not require any initialization clocks before releasing reset_n. Assuming your clock is stable, you can connect your reset_n pin to reset Nios. Altera uses the reset_counter to wait until the PLL stabalizes. Personally, I use the PLL_LOCKED signal, and logically OR it with the reset_n input pin (if either is low, then reset Nios). I use an AND symbol to accomplish this. (since we are OR'ing zeros) Hope this helps, -Terry
