12 years agonios on fpga not responding proper
Hi, I have built nios on fpga.Nios design includes clock source,nios,jtag,on-hip memory,PIO-connected to led.Then I did counter c program on eclipse.GETs 00-ff output on console window but led not...
12 years agohow are you writing to the PIO?
it should be something like this: while(1) { IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE, count&0xFF); //write a value to show Nios is alive count++; delayOneSecond(); } you can check that you are writing to the correct address by running in debug mode and manually edit the memory location and see if the LEDs change.
