16 years agoNIOS memory usage
Does Nios IDE offer a tool for reporting memory usage of my project? Basically I'd like to display the amount of space used for every memory section. Better if I could have also a complete mapp...
16 years agoThanks for your quick replies!
> don't forget to enclose the path in single or double quotes Ok, if you know the trick... > But before you are enlighten, you can download MinGW. The 'size' > utility that comes with MinGW works very well with nios2 elf images and > does so from "normal" Windows cmd.exe prompt. This sounds really great. I will give this a try and hope that i can stick to my windows cmd.exe prompt. Best regards Fred
