16 years agoNios interrupt response time
I have a custom SOPC component which has an interrupt sender (irq_n) in it's avalon interface. In my SOPC component HDL I set the irq_n line low, which causes a Nios interrupt handler to fire. In the...
16 years agoI'm investigating a similar problem under 9.1.
NIOS loses uart interrupts (characters) if data cache is turned off. Either standard or fast cores. Either standard interrupt controller or vectored interrupt controller. I took "hello_world.c" and put a "gets()" in a loop and it drops characters like crazy. It works fine if the data cache is turned on at 512. I've lost a lot of time to this. Mike
