13 years agoNIOS II/s - No output in console
Hello all, I created a project using NIOS II/e processor and it was working fine. The only problem was that it was taking too long to do some complex calculations so then I changed the processo...
13 years agoYes, the base addresses are matching. System ID verification is enabled. But no output until now.
I have also tried creating whole project from scratch again, selecting NIOS II/s from the beginning but it gives me an ELF file error and shows the following in the console: There are no Nios II CPUs with debug modules available which match the values specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary.
