13 years agoNIOS II/s - No output in console
Hello all, I created a project using NIOS II/e processor and it was working fine. The only problem was that it was taking too long to do some complex calculations so then I changed the processo...
13 years agoYou can check that the base addresses in the BSP's system.h file match the ones from the SOPC builder project. Do you have the system ID component, and is system ID verification enabled in Eclipse? It should be by default, and it's a good way to check that the BSP matches the configuration currently present in the FPGA.
As for the debugger error I've never seen en error like that, I'm sorry but I have no idea what it means...
