13 years agoNIOS II/s - No output in console
Hello all, I created a project using NIOS II/e processor and it was working fine. The only problem was that it was taking too long to do some complex calculations so then I changed the processo...
13 years agoCould you make the software flash a LED, or could you run it in the debugger, to see if it is running?
Did the JTAG UART base address change when you modified your system in SOPC builder? If yes are you sure the BSP was regenerated with the updated configuration information?
