12 years ago
Nios II/e clone
I wrote a Nios II/e CPU clone in verilog.
It takes between 600 and 800 LEs and executes most of the instructions in 4 cycles.
It comes with an ISS and a trace tool. Verilog simulation are possible under the free "verilator" tool.
I am wondering if Altera would allow me to publish this IP.
What do you think ?
Frederic
    --- Quote Start ---
    What do you think ?
    Frederic
    --- Quote End ---
    Just a follow-up : I have created an SOPC builder component for Quartus 9.1sp1.
    If I activate the "Instruction Custom Master" interface under the Component Editor, the custom SOPC component does not show up under SOPC builder.
    Here are the signals declaration in the top level:
        // Nios II Custom Master
        output        ncm_cm_reset,
        output        ncm_cm_clk,
        output        ncm_cm_clk_en,
        output        ncm_cm_start,
        input         ncm_cm_done,
        output   ncm_cm_n,
        output  ncm_cm_dataa,
        output  ncm_cm_datab,
        output   ncm_cm_a,
        output   ncm_cm_b,
        output   ncm_cm_c,
        output        ncm_cm_readra,
        output        ncm_cm_readrb,
        output        ncm_cm_writerc,
        input   ncm_cm_result,
    Is this a known bug of Quartus 9.1 ? It looks like I will be obliged to declare the interface as a "Conduit".
    Frederic
    I have added a big endian option in the core.
    Is there an easy way to tell GCC to generate big-endian code ?
    Frederic
    Look at the gcc sources, it might need a recompile.
    Howver I'm not sure how well non 32-bit Avalon slaves will work on a BE system.
    You are likely to end up in the 'mess' of ppc - where io accesses to on-chip resources all need byteswapping.
