22 years agoNios II
I have been evaluating the Nios core for the past month now. I started with the Nios I and the sdk environment. I was extreemly impressed! I was able to fit a fairly equiped Nios I into a Cyclone ...
22 years agoKenland,
I've a few quick responses. Hope they can help... <div class='quotetop'>QUOTE </div> --- Quote Start --- I am trying to port to NiosII using legacy support and I don't see how to download and run (n2r myprog.srec) through the JTAG port. AN 350 says you have to use the JTAG Uart but that it only works with Full Conversion. Can you tell me/us how to get JTAG comm with Legacy Support?[/b] --- Quote End --- I believe the original Nios downloaded code using GERMS commands.... not sure what to tell you to do here. You could always write a "legacy" SDK driver, yourself http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif ....or use the new flow and the jtag_uart driver in the HAL. <div class='quotetop'>QUOTE </div> --- Quote Start --- Also, I'm unable to connect using the debug console. It says the port is not open but when I openport lpt1 it says "incompatble p port". I'm using a parallel port ByteBlasterII. Any pointers? Anyone?[/b] --- Quote End --- Try using 'jtagconfig'. I think you might find it more useful.http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Cheers, - slacker
