SSD001
5 years agoNIOS II
Hi
I am trying to implement a IPMI protocol using NIOS II processor (economic mode) in MAX 10 FPGA (10M16SAU324I7G). While running the design i am getting the following error. Is there any way to ...
SyafieqS
5 years agoRegarding your question is there any way to make the processor occupy LUT instead of the M9K memory?
-I am not sure if there is parameter than can specify for resource type use in parameter editor for nios, If yes, you can select alm instead of m9k thus quartus will alm as resource when compile. You need to check this first.
