SSD001
5 years agoNIOS II
Hi
I am trying to implement a IPMI protocol using NIOS II processor (economic mode) in MAX 10 FPGA (10M16SAU324I7G). While running the design i am getting the following error. Is there any way to ...
SyafieqS
5 years agoHi SD,
You have to select a larger device or make sure that no interaction problems occur between RAM due to assignments made to the design. Also make sure that all RAM are assigned the correct address and control signals.
Below link could be useful reference as I found similar user encounter same issue
