16 years agoNIOS II won't run from power-on
I can't quite get NIOSII to run when power is applied. The Flash Programmer seems to work and it will start after flashing if 'run from reset' is selected. Resetting the CycloneIII hardware res...
16 years agoDo this for me ...
1 - From your Quartus project, open up the compilation report. 2 - Look in the Fitter section "Fitter->Resource Section->RAM Summary" 3 - Locate the RAM block inside your epcs_controller core (this will be down in your SoPC system obviously). 4 - To the far right, check to see which MIF file was used during compilation. Jake
