16 years agoNIOS II won't run from power-on
I can't quite get NIOSII to run when power is applied. The Flash Programmer seems to work and it will start after flashing if 'run from reset' is selected. Resetting the CycloneIII hardware res...
16 years agoYes, I have looked at the data transfer from the EPCS and it is as expected - the first transfer is all from the EPCS chip, then Config Done goes true and another 15ms period of activity follows including both data to and from the EPCS chip.
