16 years agoNIOS II won't run from power-on
I can't quite get NIOSII to run when power is applied. The Flash Programmer seems to work and it will start after flashing if 'run from reset' is selected. Resetting the CycloneIII hardware res...
16 years agoIf you have a scope available, using FPGA config done as a trigger and look at the data output of the Flash. The EPCS controller should be loading the data from the flash and there should be a long string of ones and zeros ( your elf code ). I've never had this issue, so I haven't looked at how the elf is loaded, but it will most likely be in small bursts because the CPU is executing code at this point.
