16 years agoNIOS II won't run from power-on
I can't quite get NIOSII to run when power is applied. The Flash Programmer seems to work and it will start after flashing if 'run from reset' is selected. Resetting the CycloneIII hardware res...
16 years agoIs there an LED on the FPGA config done line? Is there a way for you to confirm that the FPGA is getting loaded on power-up independent of software?
