16 years agoNIOS II won't run from power-on
I can't quite get NIOSII to run when power is applied. The Flash Programmer seems to work and it will start after flashing if 'run from reset' is selected. Resetting the CycloneIII hardware res...
16 years agoThe bootloader is part of the epcs_controller component (in onchip memory).
Are you sure you're programming your flash properly? What exactly are you doing to program flash?
