16 years agoNIOS II won't run from power-on
I can't quite get NIOSII to run when power is applied. The Flash Programmer seems to work and it will start after flashing if 'run from reset' is selected. Resetting the CycloneIII hardware res...
16 years agoThank you for the suggestion but the 'log_port' is already set to 'none' so I don't think it can be the same problem.
It is possible the boot-loader is missing - once the code is in RAM everything is fine after any form of reset - but how do I tell and how do I ensure there is one present?
