16 years agoNIOS II won't run from power-on
I can't quite get NIOSII to run when power is applied. The Flash Programmer seems to work and it will start after flashing if 'run from reset' is selected. Resetting the CycloneIII hardware res...
16 years agoTry to disable Settings/Advanced/hal/log_port in bsp editor. Without disabling Nios II seems to wait for a jtag connection. Works fine for me.
