16 years agoNIOS II won't run from power-on
I can't quite get NIOSII to run when power is applied. The Flash Programmer seems to work and it will start after flashing if 'run from reset' is selected. Resetting the CycloneIII hardware res...
16 years agoThere is an epcs flash controller compiled into the hardware and the reset is directed to its base address; I've assumed that is enough to make the bootloader function. Is there anything else that needs to be done?
