16 years agoNIOS II won't run from power-on
I can't quite get NIOSII to run when power is applied. The Flash Programmer seems to work and it will start after flashing if 'run from reset' is selected. Resetting the CycloneIII hardware res...
16 years agoSo I assume you're setup to boot your NIOS from the EPCS flash? Are you certain that the EPCS bootloader was compiled into your FPGA image?
Jake
