13 years agoNios II with on-chip Dual port ram between Nios and External DSP
Hello, I'd like to implement a dual port ram using on chip memory, with one side connected to the Avalon bus and other connected to an external DSP. Not sure where to get started; I can not se...
13 years agoIf the clocks are different you'll get 'random' data if a read and write to the same location happen 'at the same time' (probably with any overlap between the two clock cycles).
You'll need to ensure that this doesn't happen, or that the read values don't matter.
