16 years agoNios II Verify Failed problem
Hi, I'm new on Nios II. Yesterday I made a led running project, and when I debugged, it didn't work well,and I found this: Verifying 00001000 ( 0%)Verify failed between address 0x1000 and 0x18B3Le...
16 years agoI had a similar problem in a situation when I moved from sdram to sram the exception vector, which I think is made of those 0x8b4 bytes.
Try opening sopc builder and change the setting in Nios processor properties. Anyway I couldn't investigate deeply the problem when it happened to me, so I hope some Guru will clarify this point, if this is really related to exception vector. Regards Cris
