16 years agoNios II uClinux for Altera
i have to install uclinux for nios ii processor. where do i install uclinux, should it be installed in linux or in windows operating system? currently,i have both ubuntu(karmic version) as li...
16 years agoHi,
I am trying to boot with uClinux and tried the following http://nioswiki.com/linux/linux_quick_start, but as you see I encountered a problem. ~/nios2-linux/uClinux-dist [NiosII EDS]$ nios2-configure-sof /home/user/Altera/kits/cycloneIII_3c25_niosII/examples/standard_cd/cycloneIII_3c25_niosII_standard.sof /opt/altera10.0sp1/quartus/adm/qenv.sh: line 109: warning: setlocale: LC_CTYPE: cannot change locale (en_US): No such file or directory Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag -o p;/home/user/Altera/kits/cycloneIII_3c25_niosII/examples/standard_cd/cycloneIII_3c25_niosII_standard.sof Info: Using programming cable "USB-Blaster [USB 7-1.1]" Info: Using programming file /home/user/Altera/kits/cycloneIII_3c25_niosII/examples/standard_cd/cycloneIII_3c25_niosII_standard.sof with checksum 0x006ED7F9 for device EP3C25F324@1 Info: Started Programmer operation at Wed Sep 15 16:57:36 2010 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020F30DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Wed Sep 15 16:57:37 2010 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 77 megabytes Info: Processing ended: Wed Sep 15 16:57:37 2010 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:00 ~/nios2-linux/uClinux-dist [NiosII EDS]$ nios2-download -g images/linux.initramfs.gz Using cable "USB-Blaster [USB 7-1.1]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 5283KB in 46.7s (113.1KB/s) Verified OK Starting processor at address 0xD0000000 ~/nios2-linux/uClinux-dist [NiosII EDS]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB 7-1.1]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) What did I do wrong? I checkout-ed and update-d my uClinux-dist before make and in which I press ENTER for (NEW).
