21 years agoNios-II SOPC UART delivers wrong bytes
We use the UART in our Nios-II design that comes with Quartus 5.0SP1 and Nios-II 5.0 We face the problem that sometimes the Uart reports wrong RX Bytes from correct RX streams. The serial str...
21 years agodid you try 50 Mhz as clock ?
I use Quartus 5.0 Nios 5.0, no OS clock 50Mhz and uart baudrate 115200 I changed circular buffersize in avalon_uart.h (from 64 to 2048 bytes) We use Hyperterminal and ymodem file download to nios with no retransmits (uart works ok). I had tow pitfalls with RS485 (older projects) I can remember, 1. use 1k pullup,pulldown (BIAS resistors) to VCC and GND to get a defined level if no device is active on the bus. 2. to switch of the rs485 tranceiver it is sometimes dangerous to use a "transmit register empty" interrupt, (perhaps data is still present in the transmit shift out register, tx still running)
