21 years agoNios-II SOPC UART delivers wrong bytes
We use the UART in our Nios-II design that comes with Quartus 5.0SP1 and Nios-II 5.0 We face the problem that sometimes the Uart reports wrong RX Bytes from correct RX streams. The serial str...
21 years agothere is timing problem.
with UART baudrate = 115200bps and System Clock 48Mhz SOPC calculate baud error. that is almost 0.04%(maybe 1byte data loss per 20byte stream) but. Set system clock to 50Mhz that is <0.01% so, I have set system clock to 50Mhz, and test some long UART datastream. (50Kbyte) that looks perfect.(single thread test) now I have two problems. one is how to check datastream end.(for now using timeout method) the other is testing in multi thread environment.
